585,660 active members*
3,380 visitors online*
IndustryArena Forum > CAM Software > CamWorks > Using the Machine Simulator
    Mar 2008
    81
    Hi People
    Wondering if anyone uses the Machine Simulator in CAMWorks and there thoughts on it.
    Now to the question on the Machine Simulator, and it is, does anyone have or know of a tutorial/walkthought of how to create a new machine for this software as i'd like to "See it run on my machine" before i run it.
    Any help would be great thanks
    Will
    Dec 2011
    i do not use machine simulation because it is too slow.
    Nov 2012
    7
    I do use the simulator for our 5 axis machines. It does show the simulation for the machine but not all of the movements, for 5 axis. Nor does it show stock removal.
    It does show the simulation for each tool path and the crashes. It is very helpful for tight areas, im sure very helpful for 3 axis.
    Let me know if I can help you any other way.
    Feb 2013
    I dont use the Machine simulator... I use the toolpath simulator a lot to check if the part will be machined correctly
  1. As A CNC Simulator ONLY
    By MetalShavings in forum Mach Mill
    Last Post: 10-17-2010, 12:22 AM
  2. cnc simulator
    By Radosl81 in forum Want To Buy...Need help!
    Last Post: 09-29-2008, 01:13 PM
  3. Simulator
    By chrisryn in forum EdgeCam
    Last Post: 06-26-2008, 07:56 PM
  4. CNC Simulator
    By dfedwards3915 in forum Education - Teachers and Students Hangout
    Last Post: 05-24-2007, 04:52 AM
  5. CNC Simulator
    By rhino in forum Uncategorised CAM Discussion
    Last Post: 11-01-2006, 08:49 AM
