586,011 active members*
4,310 visitors online*
Thread: chamfer mill
    Feb 2011
    41
    chamfer mill
    this maybe a dumb ? . I got a job requiring use of chamfer mills ( 120 deg and 90 deg ) when setting up the tool library for chamfer mill It does not make sence these end mills look like a v with no flute . :drowning: how do I go about this ?
    Jan 2004
    3154
    Just BS it.
    Measure the (Z) depth from tip to end of flute with your scale and type it in.
    Check your simulations and see if it does what you want.
    With 2.5d programming I just use a profile Mop on the edge of the hole (or profile), set my Z depth to how deep I want to cut up the flutes of the tool (above the tip) and then use a negative stock value (on the first page) to suit how big a chamfer I want.
    May sound confusing but it is very quick and very easy.
    www.integratedmechanical.ca
    Feb 2011
    41
    I teated them as a flat mill and stepped down . worked realy well . thank you darebee
    Jan 2004
    3154
    U got it - Pontiac
  1. Chamfer chamfer mill or ball mill
    By fjbart70 in forum Mastercam
    Last Post: 03-11-2011, 06:27 PM
  2. help with 3d chamfer
    By Justin Cavender in forum Mastercam
    Last Post: 01-23-2011, 10:56 PM
  3. Having trouble with chamfer mill
    By Janos in forum FeatureCAM CAD/CAM
    Last Post: 10-15-2009, 01:16 PM
  4. Chamfer mill
    By CNCMike in forum MetalWork Discussion
    Last Post: 07-28-2008, 10:12 PM
