584,841 active members*
4,608 visitors online*
    Dec 2011
    Fanuc Amadan O4P-c
    I have very old CNC Punching machine
    it is AMADA PEGA 244 with CNC Fanuc O4P-C
    I Have 2 Problems
    1st
    the problem was that in start up in cnc mode it give message Power off Start Again when i select MMC mode it show 3 alarms
    1- Alarm 100 parameter write Enable
    2- Alarm 417 servo Alarm x Axis parameter
    3- Alarm 427 servo Alarm Y Axis Parameter
    I entered to parameter list i find most of it zeros . I haven't the parameter list of the machine . also when i press on MDI push bottom it is not active . i want the procedure to change the parameters.
    2nd
    while one of my friends want to help me to fix the problem he remove the battery while the power was OFF . after that when switch the power on again we find in CNC mode new message '' SYSTEM ERRO''. and in MMC mode the page of alarms and parameter not come it stop after checking memory then i couldn't even go to parameter pages now .
    i need help from my friends here to fix all this problems .
    best regards
    Attia
    Oct 2005
    89
    Hi Attia,
    You probably have a "Blank" memory, as you removed the "BATTERY" while the machine was powered OFF. Solution is to restore the parameters, by way of "IMPORT" from Floppy or Tape or any other means. or if you have the Printed List, go on manual Input of same. i had similar problem, but fortunately i had all parameter screen captures with me...so i went with manually input all the Params and bingo....!
    Pitre
    Jan 2011
    13
    Re: Fanuc Amadan O4P-c
    Hi Pitre,
    Do you still have the backup parameters for the Amada Pega 244 04PC ( Punch Machine ) ?
    I am also in need for parameter ofr the Amada Apelio II 357 05PLA( Combi machine Laser Punch ).
    If you have them and could provide a copy i would be very grateful
  1. Fanuc/Amadan 03P parameters page
    By rszemeti in forum Fanuc
    Last Post: 07-29-2016, 07:37 PM
  2. The big Problem - Fanuc Amadan 04P-C
    By jakubwieckowski in forum Fanuc
    Last Post: 03-26-2016, 03:24 AM
  3. Replies: 0
    Last Post: 01-28-2014, 04:41 AM
  4. amada 04pd (Amadan) setup
    By jaimeeduardo in forum Controller & Computer Solutions
    Last Post: 04-14-2011, 03:47 PM
