585,753 active members*
4,489 visitors online*
Results 1 to 8 of 8
    May 2007
    11
    MITSUBISHI MELDAS 500 SERIES
    PUMA 10 HC DEAWOO LATHE WITH MITSUBISHI MELDAS 500 SERIES CONTROL
    alarms
    1:S01 SERVO ALARM OP 0032
    2:STEADY REST PRESSURE DOWN ALARM
    I HAVE NO BOOKS/MANUAL
    Anybody with this problem.
    Jan 2011
    350
    From meau.com
    Alarm Number: S01 0032
    Document Number: USA-E99981-113-*
    Revision Date: 07/24/01
    CNC Systems
    Affected Servo System Spindle System
    Power Converter
    System Other Systems
    M600 Series MDS-A/B/C-Vx MDS-A/B/C-SP
    M60 Series MDS-A/B/C-SVJ/SVJ2 MDS-A/B/C-SPJ/SPJ2
    M50 Series Intelligent Servo MDS-A/B/C-SPH
    M500 Series
    Alarm Summary
    Related Alarms
    In-Depth Analysis
    Corrective Action
    S01 003A, 003B, 0061
    An overcurrent was detected in the IPM used by the servo or spindle drive. The current flowing to the motors was
    excessive. If the problem occurs at power up then the alarm is slightly different than when it appears at the motor
    start up.
    1) If alarm occurs at power on of the NC unit: Power off the machine at the main switch. Support the axis so it
    doesn't crash: Z-axis on a vertical machining center, Y-axis on a horizontal machining center and the X-axis on a
    turning center. Disconnect the UVW wires leading to the motor, and power on the machine. If the alarm is not
    present, then power off the machine at the main switch. Megger the motor and check the wiring back to the motor
    for shorts. If the alarm still exists then replace the drive unit.
    2) If the alarm occurs when motor start command is given, then power off the machine at the main switch and
    remove the UVW wires. Power on the machine and give a start command. Does the alarm 32 appear or do you
    have a new alarm? If alarm 32 reappears, then replace the drive unit. If another alarm occurs, turn off the power and
    check the wires leading to the motor and Megger the motor.
    3) Swap the drive unit.
    4) If alarm occurs intermittently, swap the encoder with a similar encoder on another axis. If it is a spindle drive
    check the PLG signal.
    5) Check to see if the machine is mechanically sound. Check to make sure the axis will turn freely if disconnected from the motor.
    Mitsubishi Electric Automation, Inc.
    Technical Support & Service Group
    CNC Alarm Information Document
    Power Module Overcurrent
    Aug 2009
    27
    I had S01 alarm 0032 on Mitsubishi M-V5B with Meldas M520MR.
    Replaced the DK-517 sub-boards in the MDS-B-SP-75 spindle drive unit, and that has got machine working again.
    I am curious as to why the original components have failed?
    May 2007
    11
    alarm
    Jan 2011
    350
    El Gordo,
    That would be a machine side alarm. Check your pressure switch and its electrical connections and its connection the remote I/O unit. Cheers.
    Mar 2012
    12
    dear all,
    I have a problem with my machine cnc mitsubishi meldas 500M,( machine merk "Feeler" )
    if I turn on the machine appears s01 servo alarm :PR diagnosctic sometime "3A, 18, 17 " axis Y,
    and now appears s04 servo alarm : AR diagnostic 006C axis Y,
    any someone help me to resolve this one ?
    thank's
    Rudi, Batam Island,Indonesia
    Mar 2012
    12
    dear all my friends,
    I have a problem with my machine cnc milling FANUC SERIES O-M ( the merk machine matsuura) ,
    when zero return axis z can, but the axis X and Y if press for zero return always -Y and +Y over travel and also axis X when zero return always -X and +X over travel,
    Anybody help me for this problem?
    thank's before
    Jan 2011
    350
    Move your reference dog away from your OT dog and see if reference return is successfully completed. Make sure to mark down your current reference dog positions.
  1. Mitsubishi Meldas 300-V
    By firestaromega in forum Computers / Desktops / Networking
    Last Post: 10-03-2023, 08:00 AM
  2. Meldas L3 - Mitsubishi
    By tomasz987 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-10-2023, 04:52 PM
  3. Mitsubishi Meldas L3
    By hutch07 in forum MetalWork Discussion
    Last Post: 07-30-2022, 07:42 AM
  4. Mitsubishi Meldas 60S
    By BKCOM in forum Mitsubishi controls
    Last Post: 11-28-2016, 03:59 PM
  5. Help w mitsubishi/meldas 500
    By Gpl625 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-04-2011, 05:27 AM
