Originally Posted by
sklemp
Hey guys, I'm new to both the Fadal VMC 15XT that we are using and also to MasterCam. Any and all help is appreciated. Here is my setup.
When I look into the machine doors, Y is to me/away from me, X is to the right/left.
If I place a block in my machine, I want the forward most edge to be Y-zero, and the left most edge to be X-zero. I can do that easily with my edge finder and the SETX and SETY commands.
In MasterCam, however, I CANNOT seem to get it to set the same corner as the stock's origin. For some reason, it wants to call the parts center the origin. How can I get it to use the same stock origin as what I'm declaring in the Fadal.
The reason I have the Fadal's origin the way it is is because we have a vice in there and it is setup so that we can easily place parts in the vice.
Just to let you also know, I'm creating my parts in SolidWorks and opening them through MasterCam X5. Once I do that, I show the Right View, then do an XForm Rotate at 90, then proceed with declaring the machine and trying to setup the stock.
Thanks in advance,
