How would I line a my cnc mill to an existing bolt pattern?
I want to change an existing bolt circle. I want to make the bolt circle larger by making a bigger hole than the orginal, that is offset slightly.
Here is a drawing of what I want to do. Existing part is in black, changes in green.
The part will have a center hole that you could use to line up to, but I am not sure how I would get the part "clocked" correctly.
