I am wondering if anybody can point me in the right direction
I am retrofitting a Boss8 servo driven bridgeport.
The only servo information I have on these motors is on the name plate. (servos are Powertron 402CNSP0S72 14.2A - 58.xA peak - 146V - 30'lb)
I am wondering if I can determine the correct DCtool settings for these motors on my own.
For the resistance value, can this be measured with a multi meter?
Is there some equation I can use to calculate the correct Inductance?
I have the motor and encoder connected to the drive and am able to run the "test". The motor does move for a second then stops. I am able to hold the motor shaft with my hand and stop it from moving during this test.
Corey
