585,962 active members*
3,552 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Dumb question, but not so dumb??
Results 1 to 6 of 6
    Oct 2007
    33
    This past year, I wanted to buy a new st10 turning center. I backed out of it, when I discovered the new safety features dont really fit our onesy twosy jobs we do. Simple things like hand polishing or even facing a part and being able to see it while doing so, are impossible now. We purchased a used 08 sl10 instead. BUTTT, there is coming a point, in which I need NEW equipment, not used, and I know Im going to be pissing and moaning about simple day to day functions with them.
    So, my question is this, on a new milling center, if the spindle will only go to 750 rpm with the door open, how in the world are you using an edge finder?? (since they work best around 1400 - 1500). Are you forced into an electric unreliable one?? Are you forced into some sort of expensive tool probe?? What is your process to do the most simplest of tasks when the machine itself wants to stop you from doing it????
    Yes, dumb question I know, but not so dumb on this end.
    Gary
    Feb 2009
    6028
    The simple answer is make yourself a copy of the door key. The one that engages the lock. Put a lanyard on it marked for set up only.
    Nov 2005
    56
    Unscrew the key and stick it in the lock.
    Do so at your own risk
    Aug 2010
    579
    You can use a larger diameter edge finder, or just run yours at 750. 750 is not the optimum speed, but it still works.
    Ken Foulks
    Sep 2006
    59
    Buy the probe option, you won't regret it. Seriously.
    Dec 2008
    717
    Quote Originally Posted by gixxergary View Post
    Yes. That is a dumb question. But, I can add a dumb question. What in the world is an edge finder?
    Oh, yeah - it is the stupid thing used to find edges on my manual bridgeport mill...
    Get probes and get on with it. Search for probing on EVERY one of these sites and see how many people would go back to edgefinders(nuts)
    (or just over-ride the system like pretty much everyone does...lol - not me though!)
    Tim
  1. Another dumb question
    By l u k e in forum Haas Mills
    Last Post: 06-06-2011, 12:03 AM
  2. Dumb Question
    By Pretorien in forum Benchtop Machines
    Last Post: 10-11-2007, 05:15 PM
  3. Dumb Question...
    By grasshorse in forum Uncategorised MetalWorking Machines
    Last Post: 06-28-2007, 05:15 PM
  4. One Dumb Question
    By Biggermens in forum MetalWork Discussion
    Last Post: 04-11-2007, 09:49 AM
  5. Seriously dumb CAM question
    By sploo in forum Uncategorised CAM Discussion
    Last Post: 03-09-2006, 11:55 PM
