585,737 active members*
5,009 visitors online*
Results 1 to 10 of 10
    Sep 2011
    16
    Fanuc Control Parameter
    Machine: 2011 SR20J Swiss Star
    Control: Fanuc 31i B Series
    Problem: Need to unlock Protected Programs in the 9000 range.
    Why: Need to assign 9012 (Top Cut Program) a new Program # (if possible) or output an existing Top Cut Program off another machine and input it into another.
    Sep 2011
    261
    I havent done this on a 31i control, but the following works on an 18i-TB and some earlier ones too like a 16i and the LE series
    -On the computer open up the program you want to send.
    -Change the program number to anything besides a 9000. (I usually do 00## with the number I want to change it to, so 9012 would be 0012)
    -Load the program into the machine as usual as prog # 0012.
    -Go to edit and select the program # with the cursor.
    -type in the 9000 number you want it to be and hit Alter.
    Let me know if it works!
    CNC Product Manager / Training Consultant
    Oct 2011
    edit:delete
    I tried looking through my manuals but I only have 31i model A books.
    I know there is a way to lock and unlock my 9000 programs on my star 18i though..
    unless you need a solution this weekend, I would say give star a call first thing monday morning, the guys there should be able to help you out, unless you're trying to do some funky stuff that would require you to pay them money normally.. I know the 9000 programs are stored as G codes and are typically options.. so best of luck to you.
    24220
    Not sure if this helps.
    For the 9000 9999 programs.
    Al.
    Attached Files Attached Files
    Albert E.
    Sep 2011
    16
    Thanks for the PDF file.
    Mar 2008
    443
    One caution with that PDF:
    DO NOT set passwords for that! If you do and somehow the password is forgotten, lost, or shipped out the door with the setup guy who just got binned, then the programs are locked out until you pay Fanuc technicians beaucoup bucks to fix it.
    Feb 2009
    6028
    Should just be the ne9 parameter. Just did a 31i last week. Same parameter number as the rest of the i controls. 1 locks it, 0 unlocks it. You can also use the ne8 if you want a 8000 series program.
    Al.
    I need manual operator SR20J and SB20J.
    Please help me.
    Mar 2008
    443
    Re: Fanuc Control Parameter
    Quote Originally Posted by willys95 View Post
    Please help me.
    Do you need a MACHINE operators manual, or a manual for the Fanuc control on them?
    Two very different things. If it's the Fanuc manual you need, it's not really an operator's manual, it's either a programming manual or a service manual.
    I really hated the J machines, very limited backworking capabilities.
    24220
    As PixMan says, which manuals?
    I have some Fanuc but not the SR20J OEM manuals.
    Al..
    Albert E.
  1. Replies: 0
    Last Post: 07-04-2013, 11:56 AM
  2. Replies: 0
    Last Post: 01-09-2012, 05:14 AM
  3. Parameter help on 11t control
    By YV600 in forum Fanuc
    Last Post: 03-06-2010, 01:19 AM
  4. Replies: 2
    Last Post: 12-07-2009, 11:25 PM
  5. OM Control - RS232 - Parameter
    By SHORT_JOHN in forum Fanuc
    Last Post: 04-16-2009, 12:02 AM
