I have a plasma cnc machine that I am building using 3 stepper motors. The motors are 11.2 volt, .44amp. I am using a computer AT power supply to power the motors. When I measure the voltage straight from the power supply's yellow wires, it reads 12+ volts. Once I hook it to the motor, I check it again and it is around 9v. Using Mach3, I attempt to jog the stepper in one direction and the motor whines like an old dot matrix printer sound, but nothing turns. It will jerk sometimes right when I hit the jog direction, but nothing more. I tried changing my wires around and got worse results.
I am using a laptop rated at 1 ghz, 512mb ram. Could this have anything to do with it?
Could it be that my voltage is too low to the motors?
Any suggestions?
