585,996 active members*
4,102 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Unwinding the rotary axis ( 4 axis rotary axis milling )
    Sep 2010
    I am newbie in four axis machining and i had a problem with rotating axis A where the value of A exceed 360 up to 1700 degree in the NC program which was created by powermill software
    please I want a solution for this problem such as commands will be added to the Nc program
    Thank you in advance
    Aug 2011
    2517
    (wrong)
    Posting Powermill questions here in the Fanuc section will not get you any useful answers.
    I see you also posted this question in the Powermill section........
    The solution is to re-program it the right way and/or learn how to use Powermill.
  1. Replies: 1
    Last Post: 11-17-2015, 07:37 PM
  2. A 5-axis CNC machine including a rotary axis
    By synthetiklone in forum CNC Wood Router Project Log
    Last Post: 07-12-2013, 09:32 AM
  3. Tipping rotary haas rotary axis
    By mfpuller in forum Mastercam
    Last Post: 04-04-2011, 04:16 PM
  4. 5 Axis CNC with Rotary Axis on Table
    By Shooter7 in forum Commercial CNC Wood Routers
    Last Post: 09-20-2010, 04:33 PM
  5. Rotary head development 3 axis -> 5 axis
    By Mr Helmut in forum Mechanical Calculations/Engineering Design
    Last Post: 08-03-2010, 11:26 PM
