Hello,
I'm looking to purchase a new mikini 1610LP, but I'd like to install a servo spindle drive. I'll be running EMC2, so I can make just about any kind of control work - but I'd prefer to not spend 8 grand, if I can help it.
Currently, the Baldor
BSM80N-233AF seems like it would make for a particularly strong spindle. Though, I've no idea what that thing will weigh, it's likely that the IEC80 frame size is probably the biggest I could handle.
Does anyone have recommendations on fanuc spindle servos that may also work? I'm looking for 6000RPMs and a minimum 1HP, (that baldor should provide 2.7HP, so I could easily reach 12000rpm and still have torque to spare.) I also want really high torque at 0rpm. (as much as possible)
I'll work almost exclusively w/aluminum. Steel on rare occassion. Sometimes plastics. Cutters of all sizes up-to .5" with the exception of flycutters/facing mills. Gaining the ability to use live tooling/tapping would be quite a plus.
I'm aware that there are some deals on used FANUC spindles, but what else should I possibly look for?
