hi i am running an alpha1550 centre lathe
when using turn mate i am finding that the machine has problems when cutting rad in corners i have the correct offsets in the tool settings
i have this problem when using either the streight dia with rad in corner and also in the free figure cycle the machine roughs the job out fine then the cut before the finishing cut cuts into the face of the job by up to 2mm
has any one had this problem with turn mate
thanks for any help
