584,861 active members*
4,657 visitors online*
IndustryArena Forum > Mechanical Engineering > Epoxy Granite > Custom made precision mill with epoxy-granite base
    Apr 2006
    Hi all,
    I am starting work on a precision CNC milling machine with a effective work area of 16"x11"x5" (xyz) . The machine should be able to cur aluminum and soft steel (light cuts)
    It will be made from high precision parts I have scavenged from obsolete machines on an electronics smd assembly line: pick-and-place, glue dispenser, etc. I have many parts but the main ones I will use for this project can be seen in this first video of a series documenting my progress on this project:
    [ame="http://www.youtube.com/watch?v=coJQdbMnYUc"]cnc1.mov - YouTube[/ame]
    As you will see, the xyz axis are made from linear rails , ball bearings and ball screws. There is an existing large and heavy cast iron support for the x axis.
    After reading the long epoxy-granite thread on CNCZone, I think this is the way to go to join all these parts into a working precision machine.
    As you will see in the video, my main challenge is that the various parts need to be assembled onto a base that is offset in height, I cannot just pour a single flat slab.
    One option would be to do it in 3 steps, first pour a flat slab, as flat and level as possible. Then pour the 3 offset surfaces in a second step and then position all components with leveling screws and shims and then fill the gaps under the rails and x axis cast iron support with Moglice.
    Let me know what you think!
    Patrick Robin
    Apr 2006
    Here is the video link for the first clip
    [ame=http://www.youtube.com/watch?v=coJQdbMnYUc&context=C3734d55ADOEgsToPDskL4 kUS8GBIDGY3DJakFhIau]cnc1.mov - YouTube[/ame]
    Quote Originally Posted by circaeng View Post
    Hi all,
    cnc1.mov - YouTube
    Patrick Robin
  1. Epoxy granite
    By slektning in forum Norwegian
    Last Post: 06-29-2011, 08:57 AM
  2. Epoxy Granite "s Skeleton
    By hkxy in forum Epoxy Granite
    Last Post: 05-03-2010, 02:35 AM
  3. Replies: 2
    Last Post: 01-27-2010, 01:19 AM
  4. Is a slab of granite a good base for a small (Taig) mill?
    By Hirudin in forum Taig Mills / Lathes
    Last Post: 03-01-2009, 05:19 AM
