585,692 active members*
4,794 visitors online*
IndustryArena Forum > Hobby Projects > Steam and Stirling Engines > This look like 500 watts to you?
    Mar 2005
    266
    BIG STIRLING ENGINE RUNS ON ANY HEAT SOURCE - 850RPM 58cc - FULLY ASSEMBLED | eBay
    I watched the video of it spinning a flywheel and have doubt that its 500 watts of power =/ Near the bottom of the auction he claims that if given the right conditions it can produce 500 watts 24 hours a day. That said its the biggest of the relatively cheap and currently produced stirlings I've seen as most are just toys or so well made they cost a fortune.
    Apr 2010
    294
    The whole machine look very much like the "Ky-Ko" fan which would have been powered from a kerosine burner with a wick, so not producing much power at all. Using gas to run it will give more output, but I doubt 500watts. google KyKo fan for more info.
    Looking at the crank arrangements, They look a little weedy for that much power.
    Oct 2005
    2392
    Yeah the crank in the photos looks like a nasty design, and looks sloppy/worn too.
    I'm also doubting the "500W output" claim too, even with a 50% efficiency you need to be able to apply a 1000W heat differential to it, or maybe 1300W to 1500W of heat to the hot side? That sounds like a pretty severe flame, and that is only if you get 50% efficiency out of it which is unlikely as most flame sources will dump a heap of heat upwards (lost as convection in the hot exhaust air).
  1. How to figure how much watts i need?
    By samsagaz in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-11-2012, 12:34 AM
  2. Amps vs Watts
    By Grebbo in forum CNC Machine Related Electronics
    Last Post: 04-26-2008, 06:21 AM
  3. 40 watts not enough to cut 1/32" plywood?????
    By Mrebeiro70 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-25-2007, 03:23 AM
  4. oz/in to lb/ft to watts
    By 307startup in forum Linear and Rotary Motion
    Last Post: 10-02-2007, 12:14 AM
  5. Converting oz/in to Watts
    By mikie in forum Servo Motors / Drives
    Last Post: 10-06-2005, 06:04 AM
