585,567 active members*
3,466 visitors online*
Results 1 to 7 of 7
    Jan 2010
    6
    Missing Steps, Help
    I am working on a ProBotix V90, with Probotix 3 Axis Sidestep bi-polar drivers, running 280 oz in steppers, 4-wires. I am using EMC2 software and cutting the test pattern logo that is default with the software. My machine has begun missing steps both when I jog the axis, and when it runs the program. Any help troubleshooting this issue would be appreciated. Thanks.
    Apr 2009
    5516
    Quote Originally Posted by monte0930 View Post
    Try to lower you acceleration. If that doesn't work lower your rapids speed.
    Jan 2010
    6
    OK, thank you. I will try some things with lowering the accel and speeds. I already tried lowering the speed. But I will see what lowering the accel does.
    Jul 2010
    1183
    You may be able to get more specific help from those who have the exact
    same setup on the yahoo support group....
    Fireballcnc : FireBallCNC
    If you don't get a quick answer, keep trying. Lots of people run the
    very same setup.
    (I'm not familiar enough with EMC2 myself....)
    John
    Jan 2010
    6
    Thanks for the help so far, I slowed down the max speed to 100in/min and set the max accel at 45in/s^2 now only the y-axis stutters when running the program? any idea what could cause this?
    Dec 2008
    292
    I suggest you lower speed to 40-50 in/min and acceleration to about 20% of that and run a test. If that works, increase the speed/acceleration until you get missed steps again then back off about 20%.
    Don
    Jan 2010
    6
    I also have been using the drivers set at full step and half step. I see that they can go down to 1/8 step, so I think i will try this. From what I understand, micro-stepping is they way most people are going. Still learning though, I will try going down to 1/8th step and see how that helps.
  1. Missing steps
    By kasari in forum Commercial CNC Wood Routers
    Last Post: 01-21-2010, 02:14 PM
  2. Missing steps?
    By beezerlm in forum Machines running Mach Software
    Last Post: 05-13-2008, 03:59 AM
  3. Missing steps ?
    By DavyD in forum Machines running Mach Software
    Last Post: 05-10-2006, 08:06 AM
  4. Missing Steps with Laptop
    By alanc2 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-08-2004, 08:39 PM
