585,996 active members*
3,901 visitors online*
    Oct 2007
    38
    NEED HELP WITH A .GPP FILE
    Hi! I'm trying to edit an old .GPP file for a deckel Fp4MA. Everithing is working just fime but since this machine need that z compensation must be wrote after any z changes i've discovered a mistake. It puts the D+ code after Z changes but it does this change aven after a x or y change and i can't discover where is the problem into the .GPP file. Could someone check this .GPP file? Thanks a lot...
    Attached Files Attached Files
    May 2007
    312
    Please post .gpp uncompressed because I cannot unzip anything. It might be easier to search the .gpp for "D" and see what is going on. Have you performed a dry run without a tool? the "D" might be moot.
    Oct 2007
    38
    OK here's the file... on this machine I have done only small and simple program. I found the error that was in line 488 where I put ",' D+'tool_number" after "' z'zpos" but now the only d+ i get is after tool change... or to be more precisely after the first rapid movement. For the other z movements the d+ is no longer reported. I'm not capable to do this...
    Mar 2012
    Turn your trace on in your .gpp before you post your code by taking out the ; in this line
    ; trace "all":5
    you can trace it from a value of 0-5 to get simple to more complex breakdowns of what is going on.
    Go from there and see what it gives you.
    Feb 2011
    252
    I can write a postprocessor for you. [email protected]
  1. Replies: 8
    Last Post: 05-04-2015, 12:49 PM
  2. Help Regarding STL File
    By CnCustoms in forum Uncategorised CAD Discussion
    Last Post: 01-30-2012, 03:07 PM
  3. Converting a pdf file to UG part file
    By gaoxingdcf in forum UG NX
    Last Post: 05-20-2010, 01:47 AM
  4. converting a mastercam 9 file into a Solidworks file
    By Michael82 in forum Solidworks
    Last Post: 04-17-2009, 07:14 PM
  5. Replies: 3
    Last Post: 12-11-2008, 02:45 PM
