585,599 active members*
3,665 visitors online*
IndustryArena Forum > WoodWorking Machines > Wood Lathes / Mills > Spindle motor for HomeMade Lathe.
    Mar 2005
    269
    Hey guys, i purchased a few steppers and ballscrew to make an small lathe to make small pieces (mainly less than 10cm length), Want to know if someone can recommend me wich spindle motor can i use for it, or at least what kind of specs i need to find.
    Thanks in advance
    Mar 2005
    269
    At home i have an 2HP Motor with VFD controller, max spindle are 2800RPM, i think that is a little big for the small machine :P
    Maybe will be better to make an big machine, i have some ballscrews and linear motios to make 45cm machine.
    24220
    Look for a DC motor of an appropriate size, servo etc, and pick up a KB/Balder SCR controller.
    Al.
    Albert E.
    Mar 2005
    269
    Thanks.
    What about X axis? think that 4.8kg/cm will be OK for x axis of 10cm travel?
  1. Stepper Motor As Lathe Spindle
    By 2_many_hobbies in forum Taig Mills / Lathes
    Last Post: 05-30-2012, 05:00 PM
  2. DC Spindle Motor and Drive of CNC Lathe For Sale
    By Zoni in forum News Announcements
    Last Post: 04-11-2011, 12:02 PM
  3. Spindle motor for a lathe
    By lokii in forum CNC Machine Related Electronics
    Last Post: 03-16-2011, 09:55 PM
  4. Mini lathe motor for spindle?
    By Guldberg in forum Mechanical Calculations/Engineering Design
    Last Post: 11-08-2006, 09:27 PM
  5. servo as spindle motor for manual lathe.
    By thx1138 in forum CNC Machine Related Electronics
    Last Post: 08-24-2006, 08:54 AM
