585,717 active members*
3,916 visitors online*
    Jun 2010
    Powermax 45 T45v Torch ?
    I just purchased a Powermax 45 with a T45v torch. I will be using it on a Plasmarout CNC table and was wondering what the consumables I need are. I think it will be the shielded nozzle #220671 with shield #220674 it looks like all the electrodes are the same. Let me know if I am wrong or on the right track. If you use something different and it works good let me know that to. I am new to Hypertherm changing from Thermal Dynamics.
    Jan 2008
    2247
    You should follow the specs listed in the operators manual for the Powermax45.....use the cut charts and consumables listed for the mechanized torch (even though the T45V is a hand torch). It is particularly important to use the machine torch shield (as you have listed, part number 220673) for mechanized cutting to maintain proper torch to work distance.
    45 amp shielded consumables for mechanized cutting:
    Shield: 220673, Retaining cap: 220713 (if your height control uses "ohmic contact for finding the plate use 220719), Nozzle: 220671, Swirl ring: 220670, Electrode: 220669.
    There also is a set of 30 amp consumables for cutting between 20 and 30 amps for materials thinner than 10 gauge...these unshielded consumables will allow for slower speeds and thinner kerf width. To use these consumables you need to order all of the components...Retaining cap: 220483, Nozzle:220480, Swirl ring: 220479, Electrode: 220478 (you do not need the deflector)....these are the same parts as used in a Powermax30 torch.
    Best regards, Jim Colt Hypertherm
    Quote Originally Posted by rideright View Post
  1. Powermax 85 Machine Torch, any breakages?
    By BioHazard73 in forum Hypertherm Plasma
    Last Post: 09-01-2012, 09:30 AM
  2. Powermax 65 machine torch on Torchmate 2
    By FunWestTexan in forum Hypertherm Plasma
    Last Post: 01-18-2012, 03:39 PM
  3. Machine torch for Powermax 600/800/900 for sale
    By jasonpaulbauer in forum Hypertherm Plasma
    Last Post: 12-14-2011, 04:44 PM
  4. T60 Torch on a Powermax 1250
    By Stout in forum Hypertherm Plasma
    Last Post: 08-04-2011, 10:26 PM
  5. CandCnc + Powermax 45 + Machine Torch =
    By brouser1 in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 06-09-2010, 10:27 PM
