585,737 active members*
4,717 visitors online*
IndustryArena Forum > CAM Software > Surfcam > 4th axis degrees of rotation.
    Jan 2009
    4
    Hi guys, I have a slight problem with a part we make. Machine is a Makino a61, the part is a stator vane that is located in the middle of the B axis, tool 1/2 ball nose. Any who I program the part in a zig fashion, where the mill starts at the top of work piece and spirals down. The problem is before I can get to the bottom the control alarms out cause by b axis movements are greater than 99,999*. Speed and finish are critical. I can't use zig-zag because customer is very picky, not to mention it is a little slower. Is there a remedy in surfcam or?
    Oh machine control is makino professional 5.
    Wolf
    Dec 2010
    23
    Do you have a file or picture, so i can see alittle bit more of what's going on ?
    Feb 2007
    664
    I don't know your control but I know those parts
    There should be some paramiters that let the axis roll back to zero (reset the axis)
    Jan 2009
    4
    In my post there are B movement greater than the control can read. Be nice if surfcam would zero out every 360 degrees.
    May 2007
    71
    If you are using the MPost then search in postform.m which one you are using and modify the B register.
    B ->3.>3 mod 360
    or
    B ->3.>3 mod 360 mult -1
    It just add the mod 360 for the B register!
    Then you could output 0.001 -->359.999 --> 0.001 and also postive way!
    Maybe you also need to modify your parameter about the B axis in the controller.
    If you are using SPost, you need to use SPost Configuration to modify your Uncx01.Pxx
  1. VH 65 A axis rotation
    By timo2le in forum Fadal
    Last Post: 09-08-2018, 10:13 AM
  2. A axis rotation ????
    By dunnitagain in forum Fadal
    Last Post: 07-29-2011, 01:50 AM
  3. Replies: 4
    Last Post: 04-08-2011, 05:02 PM
  4. Rotation along the y axis?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 07-09-2010, 05:27 PM
  5. X axis to A rotation
    By quemast in forum G-Code Programing
    Last Post: 06-18-2006, 02:36 AM
