585,729 active members*
4,862 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Rockwell blade runner good for cutting 2-3" thick aluminum?
    Aug 2011
    I want a small machine shop tool that can rough cut aluminum or brass extrusions to size for a milling machine.
    Space is a big factor in this, then price follows.
    I am looking at the Rockwell Bladerunner, see:
    Shop ROCKWELL BladeRunner 110-Volt Cutting Saw with Wall Mount at Lowes.com
    Is it any good for cutting 2-3" thick aluminum extrusions (maybe 4" wide max)?
    Do you have any other suggestions? I like the form factor of the bladerunner. Conventional metalcutting bandsaws are too big and bulky.
    Feb 2007
    473
    Huh, I hadn't seen one of those before seeing your question. Pretty cool little tool, basically an upside-down jigsaw mounted in a table...
    I watched a video review of it on YouTube, and they said that it only cuts up to around 1 1/2" so it's probably not quite big enough to cut your 3" extrusion.
    Aug 2011
    does it (and other jig saws alike) have the ability to cut through thick aluminum?
    Will slowing down the manual feed help?
    Feb 2007
    473
    Well the video I saw demonstrated it cutting through black iron pipe, so I imagine that aluminum shouldn't be a big deal.
  1. 6" thick material that's good for cnc?
    By markh76 in forum Material Machining Solutions
    Last Post: 09-19-2011, 09:14 PM
  2. RFQ - Aluminum 0.090" thick fins, Water or Laser cut
    By jhuebbe in forum RFQ (Request for Quote)
    Last Post: 05-14-2011, 07:51 PM
  3. Blade runner questions
    By Kentuckyfarmer in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 04-07-2011, 02:27 AM
  4. Looking for thin aluminum, 0.020" thick, sheet
    By laka in forum MetalWork Discussion
    Last Post: 06-26-2009, 06:32 PM
  5. Best Mill for 1" thick Aluminum?
    By gtslabs in forum Uncategorised MetalWorking Machines
    Last Post: 01-01-2004, 04:37 AM
