585,690 active members*
4,923 visitors online*
    Feb 2012
    Red face Universal Laser Problem
    Ive got a PLS 4.60 (70w Tube), and all of a sudden its decided the table height it -213mm. So when I run a program, it tries to wind down through the bottom of the table. Manual controls wont work either, so im thinking its might be software glitches in the driver program. Anyone else had his or similar?
    Im thinking of buying a new laser anyway, as some of our products are made with a CNC miller which is getting old, so im after a Laser with a 48" (1200mm) bed. Needs 48" (1200mm) clearance in the other axis too, but not to engrave.
    Any Thoughts?
    Cheers
    Craige
    Nov 2011
    Hi Craige,
    How old of a copy of the driver/software are you using?
    In all of the versions I've used over the past 3 years, you can set the table height under the screen on the second (or third?) tab. If it's reading negative, I suspect the machine won't allow you to move it any more. It should know what lens in in there, and then you'll want to set the table to 0.000" using their little focus spacing tool.
    I've had mine mysteriously lose that setting, and I've also had a push-button control panel fail (replaced under warranty) - both cause similar issues.
    My ULS machine is being supplemented with an imported machine that should arrive on Monday - 48x60 @ 150 watts.
    Dave
  1. Laser Cutter Universal VS Epilog
    By inertialabs in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-05-2013, 07:13 PM
  2. Universal Laser Systems Help?
    By DaveDoesIT in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-20-2011, 10:30 PM
  3. Universal Laser X2-660 - Need Driver
    By sanddrag in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-05-2011, 09:59 AM
  4. Universal Laser Cutter, roughly 10G's...
    By whyrichard in forum Want To Buy...Need help!
    Last Post: 12-19-2007, 07:09 PM
