585,762 active members*
4,085 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > turn cam work for you?
    Oct 2009
    230
    does anyone have a working dolphin turn and mach3 turn relationship?
    my 2 will not play together at all.
    any setups i can look over?
    thanks
    Dec 2007
    496
    Whats not working? You may have your settings wrong in mach3?
    Oct 2009
    230
    dophin seems to throw in some reversed radius here and there. very small and hard to see.
    i do try both ij modes and one is very much better.
    Oct 2009
    230
    it turns out that i have to start in the cad and go thru to the cam or else it wont post a usable code. funny but i can live with it.
    Jun 2004
    6618
    Re: turn cam work for you?
    I know this is an old thread. I don't know if it was a user issue only, but I pretty much ignore the CAD side. I just import DXF files from Turbocad into the Turn module.
    If you don't already have a favorite CAD package, then the Partmaster CAD is really easy to learn. It isn't required though. Just an FYI.
    Lee
  1. Mazak Quick Turn, Milling, and Work offset questions.
    By driftmaster in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-27-2014, 01:29 AM
  2. Mill/turn Multi axis work plane question
    By bassn_07 in forum Esprit
    Last Post: 06-01-2008, 09:07 AM
  3. RFQ: Turn / Mill work needed 2" dia 1018
    By dsmdude in forum Employment Opportunity
    Last Post: 09-27-2007, 03:59 PM
  4. Replies: 3
    Last Post: 12-24-2006, 04:41 AM
  5. RFQ - Simple Aluminum Work, Fast Turn-Around. - AWARDED -
    By JavaDog in forum Employment Opportunity
    Last Post: 11-17-2005, 09:25 PM
