585,969 active members*
4,569 visitors online*
Page 72 of 72 2262707172
Results 1,421 to 1,431 of 1431
  1. #1421
    Feb 2010
    3447
    Re: Hoss's 3D Printers
    In slic3r you can scale by percentage in each x, y, and z. I had to scale a model today by 2.5% larger because it was printing undersize. :/ just another way to modify without opening in cad.
  2. #1422
    Apr 2004
    128
    I am running a Gregs extruder. I would like th machine the small gear (10 tooth) out of aluminum.
    Does anyone know what pitch the gear is?
    Sean
  3. #1423
    Mar 2013
    124
    Did you end up just using nuts in those miny extrusions? Or did you find a drop in "carrier nut" of sorts? I've found upon disassembly (rebuild) that many of the nuts I was using dug into the aluminum extrusion all over.
  4. #1424
    Aug 2012
    23
    Hi Hoss et al.
    Any thoughts on someone starting out (first 3D printer) with a MendelMax 1.5 kit? Looks fairly stiff with Mitsumi aluminum frame. I'm working my way through this thread, sorry if this has been discussed already.
    -- Alan
  5. #1425
    Jul 2012
    80
    The first printer I built (and only one) was an extra large self sourced MendelMax 1.5, so you would probably be ok with a kit. It is a pretty stiff machine as is, and you can make it even stiffer if you add a bunch of metal brackets from Misumi. Overall I'd say it is a pretty well done machine, but then I might be a bit biased, since I built one.
    Michael Anton
    http://manton.wikidot.com - http://laserlight.wikidot.com
  6. #1426
    Aug 2012
    23
    Quote Originally Posted by manton View Post
    Thanks, Hopefully mine will be shipped soon.
    Now off to practice openSCAD, and make a space for another project..
    -- Alan
  7. #1427
    Jun 2011
    Hay Hoss.
    Been watching your ob14 build forever and I'm hoping to build one myself. I just completed a printrbot simple and am hoping to use it to print the parts for the ob14.. but I'm restricted to a 4"x4"x4" builds area...
    Are there many pieces that will exceed those limits?
    Thanks.
    Kevin G.
    Sent from my Surface Pro 2 using Tapatalk
  8. #1428
    I think the only one that would is the switch panel on the right side, not very important.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  9. #1429
    Apr 2006
    3498
    Finally, Hoss,i got inspirations from you and my Delta "Delta-1" is almost 60% complete.
    Attached Thumbnails Attached Thumbnails 3d skelton.jpg   Linear Bearing Parts.jpg   DSC01793.jpg   DSC01790.jpg
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
  10. #1430
    Mar 2013
    42
    I am looking to build one of the Hoss style OB14 printers and need someone to print me the parts for it. Any recommendations for someone/someplace reasonable? I didn't see anything in the classifieds. I realize this forum may not be the best place to look for this.
  11. #1431
    Apr 2006
    3498
    some of many results... I love my DELTA-1
    Attached Thumbnails Attached Thumbnails DSC02303.jpg   DSC02300.jpg   IMG_20150124_144048.jpg   Final.jpg
  1. mhackney's 3D Printers
    By mhackney in forum 3D Printer / 3D Scanner Discussion
    Last Post: 04-04-2014, 09:17 AM
  2. ROBO 3D Printers
    By CNC_Kid in forum 3D Printer / 3D Scanner Discussion
    Last Post: 01-13-2014, 09:13 PM
  3. Why have 3D printers in the classroom?
    By cncadmin in forum 3D Printer / 3D Scanner Discussion
    Last Post: 10-23-2013, 04:10 AM
  4. 3D Printers why so quite on here?
    By xairflyer in forum 3D Printer / 3D Scanner Discussion
    Last Post: 07-17-2012, 04:55 AM
