I was trying to cut some aluminium last night, but my mill's been stalling recently, and it did it again last night scrapping the part
I was cutting 12mm wide (0.5") and 1.5mm deep (0.06") with a rougher, and with my mist coolant soaking everything nicely. It started an almost full-width cut on the edge of the part (I reckon 10mm wide) and about half way along, the motor just started to bog down and stalled out after about 2s while I was scrambling towards the mill to hit the E-stop. I didn't get there in time, and the axes kept going, so the head got knocked out of alignment
I looked at the tool - thinking it might have galled up, but apart from the big chips it was trying to scrape out at 0 rpm, all the flutes were clean. The cut was at the edge anyway, so there was somewhere for the chips to go...
According to G-wizard, this should only need about 0.2kW - the mill claims to have 1.1kW so this should have been trivial, but I have a nasty feeling that either the motor or the controller are on their way out
Apart from some audible speed fluctuation at zero load, it all sounds OK, but randomly it will just bog down very gently and stall - it takes a few seconds to stall, and it will spin gently up again if you stop the axes. I've had it while drilling, as well as milling, but I'd been assuming it was just bad cut-parameters. I'm not so sure now though...
This is my 2nd motor on this machine - I'm getting tempted to bin the DC-motor and controller and try something with AC in the title...
Has anyone else had these issues on a BF30 class mill?
