Hi guys, we are building a 4x4 CNC plasma table for a project at our college. (4000$ for all, plasma cutter, electronic, raw material, etc)
you can see the 3d model below.
We will probably use linear guides from PBC Linear (still doesn't got their quote) LINK
For the Y axis we plan to use Integral V Linear Guide LINK
The driving system will use timing belt, something like Fiero Addiction Project
I plan to buy the BladeRunner3-Combo 3Axis XYZ controller with motors (300 Oz-in hybrid steppers) and cables from candcnc
We will not have a DTHC module, we got some concept for a sliding device to control the height of the torch. (this table will always cut flat 1/4" material)
I got some questions :
- Can I use 2 of the 3 motors to drive my X axis ?
- What about the limit switch for both axis ? They are not included in the candcnc package I believe. Were can I get some and how do I connect them ?
- Do we need to reduce the gear ratio for the driving system or we can set up our gear right on the driving shaft ? I assume that we need to calibrate the motor with the software ? (mach3) (One step of the motor = a travelling distance)
- If I buy the BladeRunner3-Combo 3Axis XYZ controller with motors and cables what else do I need for the electronic part of the project ? A power supply for the motors ?
Thank you for your time, every comments and suggestions will be greatly appreciated. I'm sure that i'll have some more questions soon :P
Marc-andré
