509,631 active members
3,238 visitors online
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > open source Atmel/arduino PID motor control
Page 3 of 21 1234513
Results 25 to 36 of 249
  1. #25
    Registered
    Aug 2006
    156
    Also as a sidenote my plan is to try to get this to work and if it does then also make a dual,
    same board will do my speed controls, and also do my extruder heating and heatbed control.
    i have really been wanting to do a head for 3d printing on my machine. but theat the next step
  2. #26
    Registered
    Aug 2006
    156
    i uploaded the daigrams i found, again thanks goes to the original thread starter. I assume that in the diagram a 390 saying R14 is a 390 ohm resistor. I am building a parts list now
  3. #27
    Registered
    Aug 2006
    156
    2W01G 2 amp bridge rectifier .52 from digikey
    Red led
    green led
    2x 4.7k ohn resistor
    1.2k ohm resitor
    15k ohm resistor
    2x 390 ohm resistor
    100 ohm resistor
    2x 22k ohm resistor
    470 ohm resistor
    39 ohm resistor
    PC817 photocoupler .52 digikey (few to choose from have to look)
    MOC3021 TRIAC .76 digikey
    TR Bt139x TRIAC 1.76 digikey (different models need to discuss)
    Capacitors______________________
    2x 47u
    .22uf
  4. #28
    Registered
    Dec 2010
    which circuit diagram are you going with?
  5. #29
    Registered
    Aug 2006
    156
    Quote Originally Posted by straga View Post
    Add same fix in vspindel.pde
    some photo
    Inbox.Foto
    Straga,
    Я надеюсь, что вы можете помочь нам дальше с проектом. Я уверен, что с языковым барьером трудно помочь иногда. Я ценю вас этот обмен с сообществом ЧПУ. Я надеюсь, что если мы столкнуться с проблемами, вы будете так любезны помочь. еще раз спасибо
    Тим
  6. #30
    Registered
    Aug 2006
    156
    Quote Originally Posted by mmcp42 View Post
    i am thinking the one he had that was not under "old"
    I am curious do you use skype? it be great to be able to free chat some while working on the concept my skype is timmyb46 for anyone interested
  7. #31
    Registered
    Aug 2006
    156
  8. #32
    Registered
    Aug 2006
    156
  9. #33
    Registered
    Aug 2006
    156
    I just started hacking apart random electronis around my basement that i have been thinking of taking to the dump. found an ancient pc gonna see what peices i can find in there. This might turn into quite the fun project
  10. #34
    Registered
    Dec 2010
    I just found the same circuit!
    just converting it to EAGLE so we can do something useful with it
  11. #35
    Registered
    Aug 2006
    156
    sweet i know eagle is apparently the pcb software. rememebr i am new to this. I am running to radioshack to see what parts they may or may not have there. I got a protosheild in my arduino on top and am starting to layout the stuff
    Again in case u missed it above i am on skype if at some point u want to type back and forth live. I am trying to understand the two different kinds of triacs used. where did u find the schematic? is it a different site? for now i am just gonna breadboard it up then solder i beleive. let me know what your plan is. we can work together going forward.
  12. #36
    Registered
    Aug 2006
    156
    i also see he used a pickup with a magnet for rpm. I am thinking a IR diode version if u know what i mean
  1. CNC Controller with Arduino - open source
    By Christian Knüll in forum Open Source Controller Boards
    Last Post: 12-22-2012, 10:46 AM
  2. Arduino PID Motor speed control for router
    By EL34 in forum General CNC Machine Related Electronics
    Last Post: 12-02-2012, 11:34 PM
  3. Open Source Spindle Control
    By rcpilot82 in forum Open Source Controller Boards
    Last Post: 05-27-2011, 10:25 PM
  4. EMC2 (Open Source) Plasma Control w. THC
    By rugludallur in forum General Waterjet
    Last Post: 07-19-2006, 09:25 PM
  5. Any open source or cheap driver for bipolar motor 6 Amp, 2.7V??
    By berryCR in forum Stepper Motors / Drives
    Last Post: 06-10-2006, 05:43 AM
