585,585 active members*
3,794 visitors online*
Thread: MCam X5
    Feb 2012
    MCam X5
    hey I just started using X5 after using 9 for years and years,
    can someone please tell me in plain words how to change my front view into the top so I can program it from that position. the solid file came to me oriented in a different plane / view. in 9 I could do it but in X5 th GUI is different or the command is hidden somewhere I can't find it.
    thanks for your help. I'll stumble along until I hear from someone.
    thanks
    Jan 2008
    575
    At the bottom of the screen there are boxes labeled_ Planes, G-view and WCS. Click on G-view and a menu will come up and you can change the view, but you will have to change the construction plane the same way to toolpath.
    Robert
    The beaten path, is exclusively for beaten men.
    Jan 2009
    15
    Use the X form translate 3d function select the starting plane and the then the desired plane. I would also copy this function into a new level. Good luck
    Apr 2003
    3578
    I would say this was a Solid Works file.
    Use the WCS button lower right hand corner. Go to View Manger set the WCS and C\T to front. theis will get you going right away. or try watching the video that came with X5 showing the updates you will see the Dynmic Xform much easier and better the 3d xform.
    Cadcam
  1. mcam 9 surfaces
    By Benoit619 in forum Mastercam
    Last Post: 07-02-2010, 05:50 AM
  2. Help with Mcam x3 wire
    By Cknoble1 in forum Mastercam
    Last Post: 05-17-2010, 07:52 AM
  3. Need help with Mcam and centurion 7.
    By absolut in forum Milltronics
    Last Post: 05-15-2010, 09:50 PM
  4. mcam??
    By tsutt in forum Mastercam
    Last Post: 09-26-2005, 06:03 PM
  5. MCam V8 and Fanuc 21 T
    By sleepless1 in forum Mastercam
    Last Post: 06-25-2005, 12:08 AM
