585,733 active members*
4,652 visitors online*
    Jan 2011
    51
    kelig 8060 drive
    I just finished my control.my X&Y motors spin fine but my Z make a small thump in the motor and that's all.Whats the deal?I switched the motors,cables out and checked them on X&Y to rule out bad motor or cable.Its something with that 8060 drive?Any body have any idea what to do next. I know some ones had this problem.
    Dec 2005
    594
    no message.
    Jun 2011
    692
    Have you tried swapping motor leads of the z axis to one of the other axes to see if it behaves then? It could be something mechanical or even an issue with the signal coming out of the PC. I get thumping on all 3 axes when I have an issue with power saving features on the laptop I use with Mach (part of the reason you aren't supposed to use a laptop..)
  1. Direct Drive Vs Belt Drive for a Mill/Drill Retrofit?
    By pfeist in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2012, 09:12 AM
  2. DX32 hard drive (DOM Flash thumb drive) replacement procedures. WIP
    By Cellar Dweller in forum Bridgeport / Hardinge Mills
    Last Post: 01-06-2012, 05:26 AM
  3. Kelig KL-2200VFD
    By aulie2 in forum Automation Technology Products
    Last Post: 01-02-2012, 09:33 PM
  4. WHERE TO PUT FUSES&BREAKERS IN A KELIG 3 AXIS CONTROL SYSTEM?
    By macatoms in forum Automation Technology Products
    Last Post: 06-05-2011, 06:23 PM
  5. Replies: 3
    Last Post: 07-04-2008, 12:57 AM
