585,877 active members*
3,419 visitors online*
    Feb 2012
    Talking Index C200 Program Issue
    I have an Index C200, when finishing up with the milling part of program, the machine alarms out on an L135 code and says "Channel 1 Block 13 Tool Radius Compensation Active At Transformation Switchover" and also "Channel 1 Block 269 Preprocessing Stop With Active Tool Radius Compensation". I also cant seem to get the current tool list loaded into the machine as well. Anyone have any Ideas? Thanks:drowning::
    Nov 2014
    Re: Index C200 Program Issue
    can you sent the program
  1. Index GFG250 - C200 - back to life? - Doesn't show image in the screen
    By DanielPereira in forum Uncategorised MetalWorking Machines
    Last Post: 01-28-2016, 12:37 AM
  2. INDEX GE 42 SINUMERIK 3TC C200 lost parameters
    By tbagi in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-26-2014, 07:58 PM
  3. Mazak v-15n tool index issue
    By TWPguy in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-23-2012, 05:38 PM
  4. Index c200
    By rock0 in forum DNC Problems and Solutions
    Last Post: 05-21-2011, 06:56 AM
  5. ProblemPower on Intex GU 600 (controller Index C200)
    By nbn in forum Uncategorised MetalWorking Machines
    Last Post: 05-16-2011, 08:36 AM
