585,973 active members*
4,144 visitors online*
    Sep 2011
    Cool Changing Units
    Hello,
    Anyone know how change the default Units in NC from mm to inch?
    The parasolid part is designed in inch and when I open it is defaults to mm. This is a pain that costing me hours in programming
    Thank you!
    Chris.
    Jul 2005
    Hello
    No quick fix on this one, it is a pain at times.
    When you import the original file, always go into your improt options and make sure you select inch in the units. This will do the conversion to inch if the part was originally designed in mm.
    Hope this helps
    Richard
    Dec 2005
    80
    Hello
    I do not know your software .... but having said that, can't you just scale the part by 25.4? Most s/w I have used just use units ... its up to you to choose and use the correct ones .....
    Regards
    Richard
    Sep 2011
    Thanks much!!!!
    I missed out on the option of changing units at the import stage even though i looked for it
    Thanks again!!!
    Quote Originally Posted by rjl View Post
    Hello
    Hope this helps
    Richard
    Sep 2011
    Thanks for your time. I got it working.
    Quote Originally Posted by rgammage View Post
    Hello
    Regards
    Richard
  1. Changing the measurement units
    By Troncatore in forum BobCad-Cam
    Last Post: 04-07-2011, 12:11 AM
  2. I/O Units
    By gbowne1 in forum Fanuc
    Last Post: 02-09-2011, 04:28 AM
  3. Changing units from inch/mm
    By margni74 in forum LinuxCNC (formerly EMC2)
    Last Post: 08-27-2009, 04:06 AM
  4. Setups Units
    By boyvox in forum Mach Software (ArtSoft software)
    Last Post: 10-17-2006, 03:47 PM
  5. changing units in mach3
    By sdantonio in forum Mach Software (ArtSoft software)
    Last Post: 05-01-2006, 08:33 PM
