585,663 active members*
3,102 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > RhinoCAM & DSP RZNC0501
Results 1 to 12 of 12
    Mar 2008
    16
    Has anyone used RhinoCAM with the DSP Controller RZNC0501?
    I have been using Vectric and selected G code MM. *tap file but in RhinoCAM I need the correct post processor and can't seem find the right one.
    Anyone have any suggestions??
    Sep 2006
    340
    Email mecsoft support they'll make it happen
    Hey check out my website...www.cravenoriginal.com
    Thanks Marc
    Jan 2011
    171
    Sos
    I am doing exactly the same thing right now with a new router. Trying to get the right post processor for my dsp. Did you figure it out or did they have to make you one?
    Re: RhinoCAM & DSP RZNC0501
    Does anyone have this post processor? I really need it...
    Regards
    Mar 2010
    95
    What exact you need from this PP?
    I using RhinoCAM with 0501 for years, it's a lot standart pp, working fine with 0501.
    For example you can use mach2 or mach 3 pp - works fine.
    I made few minor fixes for my comfort, you can try this one http://dfiles.ru/files/p1aaleg3j
    Quote Originally Posted by Melkiades View Post
    Thank you very much Melkiades,
    I didn't have any clue in what Rhinocam Post Processor i should use with my machine. I recently purchased this machine https://plus.google.com/photos/10173...Je7qNzO6rTMzQE, i have been making some minor fixings and i need to cut some big wood 3d parts, i have in Rhino.
    I am going to try it out this week. Any advice?
    Best regards from Portugal.
    Mar 2010
    95
    Quote Originally Posted by shapebusters View Post
    Just put spm file in Rhinoceros 5\Plug-ins\RhinoCAM\Posts\ folder
    And choose QuickCNC machine from list.
    Also google for DSP manual - it's good help for newbies. Sorry, i have only russian manual here.
    Mar 2010
    95
    Sorry, Shapebusters, i gave you wrong PP.
    This one have problem reading arc process operations like G02/G03
    Here is right one:
    http://dfiles.ru/files/alqhg26w9
    Please replace old file.
    Take a note, it's produce F codes. Good for change motion speed in process, for example for slow approach and engage.
    If you don't want it, turn it off in unit:
    MENU->ADVANCED PRO SETUP->G-CODE READING SETUP->aim to Read F code by X- button, than turn it off by Y- button, than press OK
    I add useful notes in file header in this PP. You can read it by any text viewer, e.g. notepad.
    Mar 2019
    18
    i am using haas PP with rhinocam (i am newly using it) and it works on 2 axis milling with my dsp controlled machine. today i tried holes>drill with selecting points from rhino, the simulation was fine but cnc acted weird. it moved to first point and origin than 2nd point and origin and goes on.
    would it be fixed if i use another PP, lets say PP for Mach3? or is there a custom PP like Melkiades's one, file is deleted from link btw, i couldn't dl it.
    thanks in adv
    Mar 2010
    95
    My PP not working correct with drilling cycles.
    At my 0501 drill bit not rise after cycle, move to another drilling point, and breaking tool.
    Be careful with this.
    Mar 2019
    18
    i tried with HitachiSeiki PP and it worked ok. i haven't tried on material tho, watched it drilling air but was looking alright.
    Can you please provide a sample g-code output from your machine?
    Looking forward to hearing from you.
    Quelly del Mundo
    [email protected]
    For MecSoft Support: [email protected]
  1. RhinoCAM Post Processor for DSP RZNC0501
    By sos13 in forum Chinese Machines
    Last Post: 09-04-2020, 12:26 AM
  2. RhinoCam Help
    By Micro Rotors in forum Rhino 3D
    Last Post: 09-12-2007, 03:11 PM
  3. RhinoCAM Help ... It's Gone!
    Last Post: 08-29-2007, 05:42 PM
  4. RhinoCAM PRO
    By CAM USER in forum News Announcements
    Last Post: 09-07-2005, 10:05 PM
  5. RhinoCam
    By CarveJunky in forum Rhino 3D
    Last Post: 06-19-2005, 02:27 PM
