I'm having some trouble getting a voltage reading on my Gecko G540 VDF pins.
I am using the driver with Mach3 which has been configured as follows:
Pin and Ports > Motor Outputs > Spindle is as follows:
Step pin 14, Dir pin 0, Step and Dir port 1, Step and Dir ActiveLow X (have tried opposite)
Pin and Ports > Spindle
PWM and Use Spindle Motor Output are checked
Freq. 50hz and Min. PWM 0%
M3 - Output 1
Spindle Pulley: 1 pulley, 24000 rpm, 1 ratio
After enter INPUT: M3S10000
relay is thrown (M3) connecting FOR and DCM and reads as such
my problem is that I have no voltage reading of the VDF and should have something like 4-5V I'd think (with the speed being about half max)?
I've tried with various speeds. No difference.
Any suggestions on why I'm not getting any current from the Gecko VDF
