I have just purchased an Excellon 820 spindle for my project, and it has automatic collet closer, which requires 450 PSI to operate! Apparently a "booster" is something that gets added in the line leading to the collet opener, and multiplies the air pressure going to the spindle. Anyone know a good cheap source for these? Don't need continous pressure, just a puff to open the collet at the right moment during tool change. The only ones I found using Google were continuous supply, reciprocating piston types- very expensive. I suppose I could just take two air cylinders back to back? I already have a Bimba push cylinder of small size, and If I can make my own 7X booster so I can use 80PSI shop air, it would be nice.
