585,992 active members*
6,070 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Mar 2009
    12
    Remote stop / go switch SWI cnc
    Hi all,
    I am looking for a used remote stop / go switch for my prototrak cnc milling machine.
    I assume that it is the same for most retrofit models.
    I have the Trak AGE 2 model.
    Tom
    Nov 2011
    9
    Have plans - can email
    Hi Tom in NH
    I have built several of these switches for our machines - I can send you details on what I have done if you would like - I have all the internals and you can make the case to fit however. Let me know!
    Jan 2013
    Proto Trak
    Hay ATScuba I was having the same problem with mine and could you be able to send me a diagram please and thanks
    Nov 2011
    9
    Diagrams
    Corndog - I can send you a sketch of the electrical hookup and the mechanical that I have - Are you wanting to make a complete unit or just rework some existing parts? Reason I ask is we had fixed ours for several years, but eventually the switches started failing, and the wires too - so I have actually bought connectors and pins and the crimper to make up new cables, and I have a very nice microswitch that is sealed too.
    Let me know what you need.
    Jan 2013
    Proto Trak
    I am looking to rework the one I have Im not sure how the wires and transistors hook in to the switch
    Nov 2011
    9
    Did you get what you needed with that PDF? That is a pretty basic one - I have substantially more info if you need it - let me know!
    Attached Files Attached Files
    Jan 2013
    proto trak
    Yes and it will work perfect and I was wondering if you can send me the one to make one if I need to
    Thanks for getting back with me so fast
    Feb 2009
    11
    I have made and use a remote switch that is connected to the quill and sends a signal to the control to go to the next position when the quill is returned all the way to the top. Much handier and faster than reaching for the button every time you want to move to a new hole location. Pretty simple to use, just disconnect the original remote and connect this one when you have a bunch of holes to spot, drill, tap, etc... I cut 30% off of a 3000 hole job a few months ago. $$$ I'm thinking about making some more and want to know if anyone would buy one and what would be a reasonable price. The first one paid for itself threefold on the first job. I think I can sell them for $75 plus shipping.
    May 2013
    Could you send me a pic and a way to buy one?
    Feb 2009
    11
    Yes I can, What machine does it need to fit?
    Oct 2013
    Hi Jkruger, I'm very new to this cnczone so I hope this message gets to you. I am interested in getting one of these switches. I have an LX2 controller on a 1745P lathe. Older one, around 1998.
    Oct 2013
    I was wondering if anyone knows where to get the connector for the remote stop and go switch or a part no. for it?
    Feb 2009
    11
    Do an ebay search for 206429-1 . there is some very inexpensive stuff there or go to allied electronics with the same number. You will need pins and a clamp also. i have everything you need (connector, pins, cable clamp) if that is easier for you.
    Oct 2013
    JKruger,
    Thanks for the info. We should have what I need here. We have an electronics dept. I just needed the manufacturer, but this is even better. Thanks a million!
    Pete
    Aug 2008
    573
    Re: Remote stop / go switch SWI cnc
    Sorry to dig up an old topic, but do you have the pin numbering for the stop/go switch?
    (I'm also looking for the pinout of the 14pin SWiI Q input (Z scale) if anyone has it)
    TIA
    Bill
    Bill
    Nov 2011
    9
    BillTodd,
    The wires from handle are installed into pins 1 and 4 of the Amphenol connector - they are not polarized, so either wire may go in either position
    I do not have info on the 14pin Z scale connector - sorry!
    Aug 2008
    573
    Thanks ATscuba .
    I took the cover off the encoder end of the motor and traced the wires of the X axis (I assume the same pins will be used for all axes) .
    I'll report back if all works as expected :-)
    Bill
    Aug 2008
    573
    Just to provide a bit of useful info (not much SWI info in the web)
    I have the Quill dro working now. The default settings are pretty accurate using an Easson 5um glass scale. There is a conversational scale calibration option (code 123) that asks you to set up a test using gauge blocks.
    The SWI prototrak Axes use 14pin AMP circular plastic connectors(CPC) by Tyco Electronics
    Axis pinout is
    1 - Encoder /B (wire colour yel/wht)
    2 - +5v (Red)
    3 - Encoder B (yellow)
    4 - 115vac to servo amp (black)
    5 - Screen ground
    6 - 0v Servo ground (Red/Wht)
    7 - enable (?)to servo amp (blk/wht)
    8 - 115vac to servo amp (white)
    9 - not used
    10 -PWM to servo amp (brown)
    11 -/PWM to servo amp (brn/wht)
    12 - Encoder /A (org/wht)
    13 - 0v Encoder (Black)
    14 - Encoder A (Orange)
    Stop / Go switch uses a 4pin AMP circular plastic connectors(CPC) by Tyco Electronics
    1 - Switch contact (normally open - should have some deboucing filter)
    2 - not used
    3 - not used
    4 - Switch contact
    Bill
    Bill
    Feb 2021
    Looking for information on the remote stop and go switch for ProtoTrak MX2 control. I would like to buy the components and make myself or purchase a complete switch. Mine was missing when I recently bought the mill (WEBB). Any help or leads would be appreciated!
    Nov 2011
    9
    Quote Originally Posted by oxcart View Post
    For information on the wiring see my post in this thread from Jan. 2013 - I have a diagram of the wiring on switch
    I have and can send you a BOM list of parts that I have used on switch units - the OEM units from SWI are approx $200 or so - but they don't hold up too well and maintenance on them can be challenging (they have a threaded fitting on the end that you have to tighten down and the wires get twisted some when you do that)
    PM me if you would like details and I will send
Page 1 of 2 12
  1. Adding E-Stop Switch
    By JohnLucas in forum Taig Mills / Lathes
    Last Post: 09-21-2011, 10:19 AM
  2. Cheap E-stop switch...
    By pencilneck in forum DIY CNC Router Table Machines
    Last Post: 03-27-2011, 12:01 AM
  3. Remote Cylce Start and stop button
    By R.DesJardin in forum Tormach Personal CNC Mill
    Last Post: 04-10-2009, 02:09 AM
  4. E-Stop Switch
    By crocky in forum Automation Technology Products
    Last Post: 10-10-2008, 04:34 PM
  5. Emergency Stop Switch
    By BOBINETTE in forum Hobbycnc (Products)
    Last Post: 12-28-2007, 06:41 AM
