585,759 active members*
3,863 visitors online*
    Feb 2012
    mitsubishi RA 90
    JUST STARTED RUNNING THIS MACHINE. IT CUTS JUST FINE BUT WHEN THE WIRE BREAKS IT WILL NOT RETURN TO CENTER RETREAD AND RETURN TO THE BREAK POINT. AUTO RETURN AND BREAK POINT RETURN BOXS ARE BOTH CHECKED. THANKS
    Jan 2009
    64
    You might find your breakage limit is set to 1 set it higher to make it recover. with the skip function used too it will retry the amount you set it to if it breaks a final time it will rapid around the profile and move to the next assuming if you're using the micro-joint and M01 functions
    HTH
    Feb 2012
    i will try that thanks
  1. Mitsubishi FR-SE-2-22k
    By CPsystems in forum Want To Buy...Need help!
    Last Post: 06-17-2012, 04:08 PM
  2. Mitsubishi SW
    By Al_The_Man in forum Servo Motors / Drives
    Last Post: 01-31-2012, 02:38 AM
  3. Mitsubishi DWC 90 G
    By Palisadetool in forum EDM Discussion General Topics
    Last Post: 03-17-2011, 10:23 PM
  4. Mitsubishi dwc - sz EDM
    By yoopertool in forum EDM Discussion General Topics
    Last Post: 09-26-2010, 08:31 PM
  5. CH-VMC 500-Mitsubishi 60S
    By thanhct in forum CNC Machining Centers
    Last Post: 04-02-2007, 08:49 AM
