584,829 active members*
4,944 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Rogers Machine Encoder Interface Board.
    Nov 2004
    284
    Hi Guys
    Anybody using one of these Encoder Interface Boards from Rogers Machine? http://www.rogersmachine.net/index.html It looks interesting but I understand that you still need to run a second Breakout Board along with it. I like the idea of it stopping all axis movement if any one axis fails to move the correct amount. The error amount can be set to any amount in Mach. Would be interested to hear from anyone who is using one of these boards and what they think of it? Thanks for the help.
    Regards
    Willyb
    May 2005
    2502
    See also combo breakout
    Take a look also at the Campbell Designs combo breakout board. It combines a number of functions including breakout, charge pump safety interlock, spindle speed control, and one encoder input for a MPG.
    Same designer as the one offered by Rogers.
    Best,
    BW
    Quote Originally Posted by Willyb
    No, but it needs a second parallel port.
