585,763 active members*
3,974 visitors online*
    Jun 2008
    6
    Plasma steppers and drives??
    I am about to start my 8X4' router build. I would like to have the versatility of using it as a plasma also. I was told recently that i need "special" steppers, drivers, power supplies etc. and couldn't use the same setup as i would with a traditional router setup.
    Could anyone give me some advise on this matter as i would hate to use the incorrect components or setup and do damage to my controls.
    Mark!
    Jul 2005
    2415
    You would not say you need "special" steppers, drivers. power supply etc for plasma VS router.
    You do need to understand:
    The Physics of the two types of cutting are a lot different
    Plasma cutting requires high speed (150 to 300 IPM on some material) with acceleration at the higher speeds. Acceleration comes from one of two sources: More torque (bigger motors, belt reduction, etc) OR less weight on the gantry. That can be contrary to router cutting because a lighter gantry may tend to flex more given the lateral forces of milling and routing. In short you may have to build a heavier gantry and upsize the motors to do both jobs effectively. That may force other componets to have to be upsized.
    That does not mean it won't work with lighter duty components; just that it may not give optimum results on one or both processes. You might not be able to cut thinner metal and get sharp turns or square corners. You might not be able to chuck in a 1/2" mortise bit and cut dados in hardwood in one pass.
    A plasma/.router table is a compromise. Sorta like a Sports/Dumptruck. You either have to overbuild it to do both types of cutting or live with the compromises
    You also need to consider the other factors:
    Fire & sawdust (need I say more?)
    Plasma smoke and dust
    Water Tray and sawdust
    Setup time to get a flat cutting surface for the routing
    A lot of it has to do the type routing and the type plasma cutting you will be doing. To cut thinner material you need a table that can cut at up to 300 IPM and have enough acceleration to get there quickly and you need lower speeds and more torque to cut with a full sized router and cut denser materials.
    The plasma process needs more attention to noise immunity but a well designed control system should already have that.
    Cutting metal with a 30.000 degree flame vaporizes a lot of it and blowing it out of the cut with 70 PSI of air tends to generate a lot of nasty smoke not to mention hot smoking pieces falling off under the tabler. The type smoke and flame suppression for plasma is a lot different that a dust extractor at the cutting bit.
    For a shop super limited on space and that does not mind the downtime between the change over and that cleans the table completely after a job a combo table can be fun to run and highly flexible. For a shop that is looking to make money with one or the other process I don't recommend it.
    So to clarify. You can build a pretty good table to do both and if you can live with the downside your electronics can work for both. If you want the BEST (optimum) for each type of cutting you will be forced to upsize some components and perhaps move to a servo system that offers a wider range of torque/resolution and speeds.
    Tom Caudle
    www.Candcnc.com
    Apr 2003
    540
    Tom has been doing this a while and offers some great advice. Cutting speeds for plasma are definitely faster than wood, but look at your specs for the specific plasma cutter you have/want, and the metals/thickness you plan on cutting. They will provide fairly specific guidance on machine cutting speeds. Then check your needs as far as motors/drivers/power supply requirements.
    I for one built a cnc wood router and converted it to plasma. Then later bought a larger plasma cutter and converted the original back to wood routing. To be honest, there's no simple way to go back and forth between the two. I'm not saying it's not possible, but not something I would want to do. Plasma is dirty & messy. A water table or vent system will help, but the different type of table (metal slats for plasma vs smooth top with a clamp down system), different room requirements (outdoors or dedicated area for plasma vs any place the wood router table will fit), torch height controller vs z axis) and so on, make it a bit more difficult that changing your router spindle for a plasma torch. Even outdoors on your driveway, plan on hosing your drive down after cutting to clean up the mess. My plasma is in a dedicated 12x20 building with a vent system. I wish it was larger still. I'm not saying you can't switch back and forth, but its not a simple proposition. Best of luck what ever you decide.
  1. Advice please: Drives and steppers
    By lukaspanic in forum DIY CNC Router Table Machines
    Last Post: 05-18-2011, 03:12 PM
  2. Slo-syn drives & steppers
    By Appalachiatools in forum CNC Machine Related Electronics
    Last Post: 04-16-2009, 01:23 PM
  3. Want Gecko Drives for Steppers but Need Help
    By wganders in forum Gecko Drives
    Last Post: 12-05-2008, 02:16 AM
  4. Servos, steppers, drives and encoders, Oh my
    By MobilDave in forum Servo Motors / Drives
    Last Post: 09-10-2004, 01:04 PM
  5. steppers or servo drives
    By mmjpotter in forum Gecko Drives
    Last Post: 03-30-2004, 09:56 PM
