So I had installed that 'Su2stl.rb' plugin. to export the file as a .STL.
The object I am cutting out is already welded together, in the Overall Dimensions of 43.63" x 14.5". And it needs to have a profile cut out of it like this:
|_
That degree is about 16.
Imported within the error tolerance, but for some reason, the object is white. Not colored blue like it usually is. And when I go to 'Mill 3 Axis' it, it wants to cut out the whole center area, instead of focusing on the main area.
Does anyone here use Google Sketchup Pro along with BobCad? And does it work well?
Any information on it would be great.
