586,009 active members*
4,880 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > moriseiki lathe CL-25 wont let me chuck by ID
Results 1 to 6 of 6
    Nov 2010
    Hi everybody,
    I'm confused on why my lathe doesn't let me run a program or even turning the spindle on when chuckin a part by ID.
    Anybody??!!
    May 2004
    4519
    Do you have a switch on the control panel for OD/ID clamping? Do you have position sensors on the draw tube at the drive end of the spindle?
    Nov 2010
    There is no switch.
    The limit switch I would have to ask my maintenance guy because I'm not sure.
    I remember that okuma lathes would turn on a led when chucking by ID and a different led when chucking by OD.
    Mori does not have this option
    May 2004
    4519
    If you have the positions sensors, you might have to remove one cover, but they should be clearly visible on the top of the draw tube assembly. They are put there to be adjustable by the set up machinist. They are there as a safety so that the chuck will not turn if it senses that there is no material there by moving to a different position that is out of range from what was set.
    Feb 2009
    6028
    Custom button
    Operator panel soft key
    Toggle chuck I'd/0d
    Yes, the prox switches need to be set correctly.
    Dec 2021
    Re: moriseiki lathe CL-25 wont let me chuck by ID
    Quote Originally Posted by david rendon View Post
    There is no switch.
    Hi David,
    How did you get the chuck to ID clamping.? I am having the same problem here.
    LP
  1. Moriseiki lathe CL-25 Programming Manual
    By david rendon in forum Machinery Manuals / Brochures
    Last Post: 07-08-2018, 05:59 AM
  2. Replies: 8
    Last Post: 04-18-2014, 02:03 PM
  3. X3 Chuck holder wont go into the spindle.
    By Megaplow in forum Syil Products
    Last Post: 01-04-2013, 01:41 AM
  4. Example of a local sub on a Moriseiki CL25 Lathe
    By david rendon in forum Fanuc
    Last Post: 04-10-2012, 03:14 PM
  5. fagor 8055 wont jog lathe
    By jbrookes in forum Fagor Automation
    Last Post: 05-16-2011, 03:39 PM
