586,011 active members*
4,215 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Plasma, EDM / Other similar machine Project Log > Thermal Dynamics Cutmaster A120/ Raw Arc Voltage card from CandCnc
    Sep 2007
    18
    The rear of the A120 has the conector plug with a diagram of the pins, 3 & 4 are start stop; 12 & 14 are ok-to move; 6(+) & 5(-) divided arc voltage. I have the MIC-02; raw arc voltage card; thc sensor pwm; usb to rs485 high speed serial adapter from CandCNC. I'm not sure if i even need the RAV card now or what I really need to install/ hookup. If anyone has set up an A120, I need some help please. The A120 also came with a conector with a cord not sure what this is for and the clip that goes on the torch head. Thanks, Tim
    Jul 2005
    2415
    The A series units do not come with an internal voltage divider card unless you order it special (Automation Interface Card). I think you will find that pins 5 & 6 have nothing connected. The other pins work as labeled.
    You have everything you need to connect up the A120. The RAV-01 is installed inside and the TIP VOLTS connections goe to the RAW ARC VOLTS (undivided volts) in the unit (see their manual to find the spot to connect) The RAV-01 ships with two cables. You don't need the 4 pin cable. Just the shielded stereo cable. It plugs in the jack on the RAV-01 and gets routed out to the THC Sensor PWM module on the outside.
    The MIC-02 cable plugs in the CPC connector in one end and into the 4 pin jack on the THC SENSOR PWM on the other end.
    Thats it. you don't need any other cables, cards or clips.
    The DTHCII manual covers all of this in detail with illustrations and stuff for the TD units
    TOM caudle
    www.candcnc.com.
    Sep 2007
    18
    Thanks Tom, I found it, it seems that I misplaced a couple of the pages when I printed out the manual.
  1. thermal dynamics cutmaster 51 help
    By ringomike in forum Waterjet General Topics
    Last Post: 01-29-2016, 06:19 AM
  2. Thermal Dynamics A120 max cut
    By Dirrtymaxx in forum Torchmate
    Last Post: 12-31-2010, 08:24 PM
  3. Thermal Dynamics Cutmaster A80
    By Flyinfarmer in forum Waterjet General Topics
    Last Post: 02-20-2010, 04:01 PM
  4. Thermal Dynamics cutmaster 101
    By SybleK in forum News Announcements
    Last Post: 01-15-2009, 11:20 PM
  5. Thermal Dynamics Cutmaster 101
    By tuknrm in forum Waterjet General Topics
    Last Post: 11-19-2006, 10:52 PM
