585,930 active members*
3,918 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport series 2 Interact 4 With Tnc 145 Parameters needed
    Feb 2012
    Hey All
    I bought a Bridgeport series 2 Interact 4 With Tnc 145 but it lost its parameters, I have been searching this forum and have just came up with parameters for the interact 3.
    But can I use the parameters from that one, or can anybody help me with a link or the parameters.
    Here are the parameters I found in here.
    And what about a manuel for the Bridgeport series 2 Interact 4 does anyone have that?
    Thx
    Christian Ulberg
    Attached Files Attached Files
    1121
    Interacts do a few things differently than the r2c3, for instance y homes out on an interact and in on an r2c3. Series 2 may have different things than series one, so if you find a s2 interact it should get you close. If it is not already in the heidenhain parameter thread, and you find it, post it there
  1. Bridgeport Interact 520/Heidenhain TNC 155 initial parameters
    By jeromir in forum Bridgeport / Hardinge Mills
    Last Post: 07-28-2018, 10:40 AM
  2. bridgeport interact 1 lost parameters
    By thomasmc in forum Bridgeport / Hardinge Mills
    Last Post: 02-02-2015, 10:35 PM
  3. Bridgeport Interact 412/Heidenhain TNC 250 initial parameters
    By pedrow in forum Bridgeport / Hardinge Mills
    Last Post: 09-26-2014, 08:11 AM
  4. Bridgeport Interact 720VMC auto lube parameters
    By FLjoyride in forum Bridgeport / Hardinge Mills
    Last Post: 07-06-2011, 05:46 AM
  5. Bridgeport Interact 720 parameters
    By M.G.Machinist in forum Bridgeport / Hardinge Mills
    Last Post: 01-08-2010, 01:04 AM
