585,996 active members*
4,575 visitors online*
    Sep 2011
    54
    Problem running first part
    I am attaching a link to help describe my problem. My torch goes down measures the material then comes up and moves across the part about and inch high over the metal. I don't know if I have something wrong in sheetcam or Mach or what? Any help would be greatly appreciated.
    Note: I removed torch and replaced with wood to prevent damage to the torch.
    [ame=http://www.youtube.com/watch?v=1yg61M8qo60]cnc plasma - YouTube[/ame]
    Thank you.
    May 2010
    63
    Did you run a voltage test ? I can tell you this ,voltage is everthing in plasma cutting . You should watch the voltage readout on the mach screen when the torch is fired . The voltage should reach the same number as the preset voltage for the material , as suggested by your plasma cutter manufacture . Also grounding is everthing . The ground clamp from the cutter needs to attach to the material . Thats a place to start .
    4
    Have you edited your post proccessor in Sheetcam for the torch offset. If you post your g code we could better help. Chris
    Sep 2011
    54
    thanks for the info.. I got it working. It was a switch the raised the torch when an error was present. Thanks again.
  1. Problem when running
    By Rstrange in forum Torchmate
    Last Post: 01-18-2011, 04:13 AM
  2. problem running program
    By mehdiF in forum Fanuc
    Last Post: 11-22-2010, 08:27 PM
  3. Tool offset problem when running
    By lifestill in forum Machines running Mach Software
    Last Post: 02-25-2010, 07:02 PM
  4. Just got my Tormach up and running and having a problem, need some help
    By mike@newera in forum Tormach Personal CNC Mill
    Last Post: 12-25-2008, 06:50 PM
  5. NexMill-15 Up & Running!!! Part #7 Posted
    By FrankG in forum DIY CNC Router Table Machines
    Last Post: 04-27-2005, 09:38 PM
