585,977 active members*
4,113 visitors online*
    May 2008
    12
    Quick Change Tooling???
    Hey Everyone.. I am making a 24x36 cnc router / mill.
    I want to try and make a quick change tool / collet setup so I can set my tools up before I do a run then just change them out as needed....
    Is this possible? Has anyone made a custom spindle and collet setup?
    Thanks for any input or direction.
    Dezi
    Oct 2012
    4
    look into setting up the bit itself as a limit switch..... by using 5v current from the breakout board and a conductive surface u can let the machine know the length of the tool... if u search limit switch on youtube there are videos on what u r talking about.....
  1. Quick change tooling
    By Open Ear in forum Mori Seiki lathes
    Last Post: 12-26-2010, 11:46 AM
  2. Need Tooling for Quick Change 30
    By StickMaker in forum Want To Buy...Need help!
    Last Post: 07-19-2010, 03:42 AM
  3. Quick change 30 tooling - any good?
    By ktmrider in forum CNC Tooling
    Last Post: 12-29-2009, 04:49 AM
  4. JLW CNC quick-change R8 tooling system?
    By sansbury in forum Benchtop Machines
    Last Post: 01-21-2009, 10:18 PM
  5. Quick Change 30 tooling deal
    By camarogod98 in forum Bridgeport / Hardinge Mills
    Last Post: 05-13-2007, 04:22 PM
