Just kicking around a few ideas in my head before I start into a cnc router project. As usual I am getting ahead of myself with thoughts of it having a 4th axis, but I want to ask around to find out if anyone had used this idea before.
I have a 40" wood lathe that would seem to be the simple low cost solution for an easy to add and remove 4th axis on a router table bed. The lathe already has a solid spindle setup with a range of chuck options and a tailstock which is always in alignment with the headstock. All I can think that would need to be done is the addition of a stepper/servo motor and drive belt setup. With this type of 4th axis I could setup the lathe for alignment once under the router and make pin stops for replacing it to the same spots when not in use. Also when not in use it can go back to its old job of being a wood lathe.
Anyway just a thought, let me know what you think or any other considerations to take into account.
Bowman
