585,880 active members*
9,088 visitors online*
Results 1 to 7 of 7
    Nov 2010
    9
    Chnc Turret Problem
    I have an early chnc and my turret only indexes to 4 positions. When any of the other 4 positions are called up the turret functions properly and turns but then it over shoots the position. I haven't had this machine very long and would like to know if anyone may have an idea what to look for.
    Jan 2012
    21
    What model machine? Is it the newer VDI with a servo motor.
    Nov 2010
    9
    Re: Chnc Turret Problem
    Slow down air motor it may help.
    Nov 2011
    39
    I have most parts to your chnc cheap just make an offer ! Sold just the turret gear .
    Thanks Ed
    [email protected]
    Nov 2011
    39
    There is a cover just behind turret . Remove and adjust sensor over the correct station . Just did this on my CHNC II
    [email protected]
    Aug 2022
    i had an issue just yesterday where the turret would raise and just keep spinning, i swapped out the encoder and this did not fix the issue, next i changed the solenoid that stops the turret and once again this did not fix the issue. i found that the indexer motor has a valve, this piece upon inspection was full of what seemed to be rust from possible water in the system over the years. swapped part and all is good once again. hope this helps.
    Aug 2022
    Went to put this machine back together and now my turret stop won’t actuate, anyone know what this may be ? Any help would be appreciated.
    Feb 2010
    81
    Quote Originally Posted by HernandezTech91 View Post
    Are you still on this forum, Hernandez? I'm working on my chnc2 also, but my turret encoder is fried and I'm looking for info from an original part.
  1. Any one familiar with CHNC ll turret?
    By paynebros in forum Hardinge Lathes
    Last Post: 08-03-2013, 05:48 PM
  2. WTB hardinge chnc turret plate.
    By nate in forum Hardinge Lathes
    Last Post: 01-30-2012, 09:46 PM
  3. CHNC Turret with PLC...CONVERSION LOG.
    Last Post: 07-25-2011, 06:07 PM
  4. chnc I turret up problem needs a clue
    By nakatome in forum Hardinge Lathes
    Last Post: 11-03-2009, 10:54 AM
  5. Hardinge CHNC turret woes
    By Karl_T in forum CamSoft Products
    Last Post: 12-19-2006, 10:54 PM
