586,024 active members*
3,679 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Running reduced balls in a ballscrew
    Oct 2005
    78
    Has anyone tried running fewer balls in a ballnut? Aside from the obvious disadvantages regarding the decrease in load handling capability over stock, Are there any other disadvantages to be found in running a screw 16% low on balls? In my case 30 possible balls per circuit, reduced to 25?
    May 2005
    1810
    While it is obviously not what the manufacturer had in mind I think that as long as you are not approaching the loading limits of the screw then you will be fine.
    I can not see where running it with a few missing is going to damage anything or create any backlash.
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Mar 2004
    761
    Talking
    Corvus -
    Curious - Did you open a ballnut and a few escaped?
    Oct 2005
    78
    No this is in regards to the screw I bought off of Ebay, and some of the balls inside were literally crushed to powder. I've never had one of these apart, so I don't know the internal geometry. also, the crushed balls are about 17 in number if my ball count per circuit is correct for the screw, and that seems excessive, according to the number of pieces I found...
