Originally Posted by
qwerty123456
I want to machine some custom auto parts from 3 inch thick 6061-T651 Aluminum.
[Does the machining go all the way to the bottom of these parts? Most cutting tools are only 3 inches long, total.]
How much Horse Power would I need on the cutting motor?
[It's hard to say. Some machines that cut aluminum use as little as 1/3 hp, but they go pretty fast and are intended for small tools. How big a tool are you using? The bigger the tool diameter, the more torque you'll need.]
Could I use a dremel, or hand drill for the cutting motor?
[Not very effectively.]
Would a 1 HP electric motor work?
[It's possible, depending on the motor, the pulley ratio, and the tooling.]
Would 880 oz-in stepper motors work for the table?
[Maybe - or they might have too much induction, or if your static forces are too high they might not be beefy enough. You need to balance the load, the drives, the power supply, and the expected level of performance to figure out the optimum configuration for your machine.]
I don't care if it would take days to machine one part.
[You might not, but that Dremel tool would be long dead...]
I have no time constraints on production, since they're just for me.
