585,589 active members*
2,858 visitors online*
Results 1 to 6 of 6
    Mar 2012
    6
    need help in heidenhain itnc 530
    hello everyone!
    i'm working on a hermle c-30 heidenhain control and i would like to set datum automaticly using a program (i would like to be at a certain coordinate and "save" it in the preset table- the values of x,y,z,c,a)
    can anyone help me
    Nov 2008
    69
    Check the SYSREAD (ID270) and then SYSWRITE (ID 503)
    You can read the axis values and then writen them to the PRESET table.
    Fairly easy function. (you need to enter the CODE NUMBET 555343 to get the SYSWRITE functions available. Everything is in the normal user manual.
    Jukka
    Mar 2012
    6
    thank you for answering i found that on the manual , but could you post an example on how i write it in the program i would like to be in a certain position and read and write the coordinates in a different home number how do i do it?
    Nov 2008
    69
    Here is an example:
    0 BEGIN PGM test MM
    1 FN 18: SYSREAD Q1 = ID270 NR1 IDX1 ; Read X-axis position
    2 FN 18: SYSREAD Q2 = ID270 NR1 IDX2 ; Read Y-axis position
    3 FN 17: SYSWRITE ID 503 NR10 IDX1 =+Q1
    4 FN 17: SYSWRITE ID 503 NR10 IDX2 =+Q2
    5 END PGM test MM
    It reads the position of the X- and Y-axes and writes them to PRESET table at line 10.
    Fairly easy, don't you think?
    Jukka
    Mar 2012
    6
    thank you very much you helped me a lot.
    have a nice day
    Nov 2019
    Hello to all. Got a question about programming peck drill cycle. Is it possible to fully retract drill out of a hole if i start to drill in pre-drilled hole? Start is set at-30mm(pilot hole depth) and goes to final depth -100mm.
  1. heidenhain itnc 530 postprocessor!!
    By piziotizio in forum PowerMILL
    Last Post: 12-11-2012, 02:20 PM
  2. Heidenhain iTNC 530
    By aslam819 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-19-2012, 08:18 AM
  3. Heidenhain iTNC 530 question
    By Brian Brown in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-19-2010, 10:53 PM
  4. TOS with iTNC 530 HEIDENHAIN
    By SheldonB in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-15-2009, 04:35 AM
  5. Heidenhain iTNC 530
    By Thanya in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-12-2007, 10:33 PM
