When I press optional stop (OSP) button machine does not stop after tool change, it continues to next tool and so on. Do I need M1 or OSP should stops without M1? Is there any parameter or setting to enable OSP?
Optional stop is M01. All machines are like this. No way to stop after a tool change without it.
no no, on the newer Mori's you can telepathically tell it to stop and it just does it if the switch on the panel is pushed in. hehe
forgot to add, it only works if your name is Luke.
funnily enough our local Fanuc repair guy is named Luke.....
Mori Seiki uses sub program for tool change if it is newer machine like the one i am working on.
It is O9001 and all you need is to edit that program. It is missing M01. If you still haven't found the solution let me know i think i can help you with that.
Example:
O9001(ATC)
M5
M9
G0 G91 G30 Z0
G0 G91 G30 X0 Y0
M19
M6
G90
M01
M99
Yes that macro is added by company that sold our machine i do not know how are tool and palette changes done elsewhere but i have it like that. And also when our last machine was delivered M01 was missing from that macro.
My company have arround 60 Mori Seiki machines (NH,NT,NL,NV) and on all of them have macros like this one.
I guess that depends on reseller (I am from Croatia and machines are from company in Italy)
It's normal to add the macro. I put them in on delivery here. I could tell that must be a nh macro. G30 isn't used on the verticals for tool change.
Yes you're right it's from NH and i will take your advice on M19 very good tip.
And who are you sir you seem to know Moris like no one i have ever met.
I might have a few questions if that is ok. I am only operator nothing fancy
Just an ex old service guy.
And don't bother with the m19. I forgot, those machines will wait for the m19 finish signal before movement.
Oh, and don't bother with the m19. I forgot those will wait for a m19 finish signal before movement.
Dam tapatalk sometimes.....,
